Very HARD to shift into first
AREA 91
PA SHO SHOP
Area 91
I've pulled the starter, but how are the pressure plate bolts accessed? Is the only way to check to rotate the engine and reach a couple fingers in there? If that's my problem, will they be noticeably loose?
You want to check each bolt as you rotate the engine over.
I like to use a "feeler guage" and try to slide it in between the flywheel and pressure plate. You should not be able to!
badgett
94 SHO MTX
North Carolina
I had the same problem with my MTX. It was the white cable bushing on top of the tranny. To test that I pryed the bushing back toward the firewall about 3/4 of and inch. Stuck a homemade spacer between the bushing and the bracket that holds the bushing and cable filling the gap. Tranny shifted smooth as silk after I did that. I didn't leave it that way but it did tell me what I needed to replace.
