Vapor lock
ALWyzBrknSHO
Springfield, MO
My car hasnt been started since july 4th, I have spark, no fuel, this is one of the reasons why im replacing the terminals cause Ive read a bad connection can make the pump not work. A couple days ago before I started switchin out the old terminals, I turned the ignition key forward but not all the way, and before I didnt think I could hear the pump but now I think I can, and I heard a gurgling sound, so am I in luck that it wont be my fuel pump? Any answers before I get these new terminals on?
ALWyzBrknSHO
Springfield, MO
Air in...my fuel lines? So should I try that trick where I turn the key into the on position, then off, then on, off, repeatedly a few times and see if it runs then?
Mike Kopstain
Arlington Heights, IL
Well I'm curious as to why you think you have no fuel? The air purging means that the pump is working. There is a slim, and I mean slim, possibility that you can cycle the pump a few times and you'll be good to go.
Here is what I would suggest:
- get some fuel stabilizer. Your problem might be as simple as this.
- Press the throttle to the floor when starting. (turn the motor over a few times first).
The bubbling is typically the result of a faulty check valve. It's nothing to worry about. It's a nuisance if anything.
ALWyzBrknSHO
Springfield, MO
Cause no fuel comin from the injectors but runs for a few sex when ya por gas into the plug wells and then burns it off. I dont know, its weird.
