Valve seal installation
tompumped
VT
Usually valve seals come with a thin piece of plastic to put over the tip so there's no possibility of tearing the seals on install. What do you guys do, hope for the best?
I have more than one set of seals and neither came with that plastic sleeve. If anyone knows of a set that does come with it, i'll buy it just for that.
http://www.felpro-only.com/blog/valve-stem-seals_/
tompumped
VT
I'm an idiot the fel pro seals are pictured with them on rock auto
just so you are aware - valve stem seals are relatively unimportant on the V6 SHO motor due to the way the shim buckets cover the top of the valves. I have taken apart engines where the exhaust valve stem seals were completely missing and those engines didn't burn more than a quart in 1500 miles. Whereas in a ohv engine, that situation would require one to add oil almost every day. so even if you nick one of the seals on install, don't sweat it.
tompumped
VT
Thanks guys.
I bought the fel pro ones real cheap if it stops me from adding two quarts of oil it's worth it. I barely noticed a difference in oil consumption in the past from new seals, so I agree.
thatSHOguy101
