Valve cover won't come off
Blast7
Rochester, NY
Are the valve covers normally difficult to get off? I can't seem to pry mine off of the head. I am unsure of how to take if off because I don't want to damage the surface of the head by sticking a screwdriver in there and taking it off.
Car of the Moment
1991 Black MTX
K&N Filtercharger
PP Motor Mounts
PP Y-pipe
Rod Shifter
Blazer Tech Fogs
"ur gonna love that sho, and everytime something breaks down..your gonna swear to all your friends that its going up for sale. and the minute you get it back you fall inlove all over again."~Blue
fredhurderjr
www.neshospecialists.com
Are you sure you got ALL the bolts out? There are 2 off to the driver's side on each cover.
I use the plug holes to pull, rather than risking gouging the seal surface.
noSHO
ohio is for hustlers
You can LIGHTLY take a screw driver to the smaller bolts that Eric and Fred were talking about. Carefully slide it under, and use gentle, but ample, pressure to help you pry up the cover. If this is your first 60k, those gaskets could really be baked on, and don't be surprised if you demolish one or both. Just hope you have a new set lying around. Of course, check first to make sure all your bolts are loose and out of the threads, and make sure the intake brackets are off of the intake. They don't have to be completely removed in the back, however, for obvious difficulty reasons.
-Dave
green/black 92
8110600 948b 02000180
You should really remove all of the bolts from the valve covers before pulling the covers off the heads. The reason for this is the long, chrome plated bolts can drag across the unprotected camshaft lobes if they are left dangling in the valve covers. The front valve cover is an easy, unrestricted lift, but the rear valve cover has interferences from the fuel lines on the passenger side and the EGR lines (ATX) or heater hoses on the driver side. Be safe always pull the bolts.
Scott
Blast7
Rochester, NY
Scott, I remember you saying that you should take out all of the valve cover bolts in a post a number of months ago. Therefor I did take the valve cover bolts out before I removed the valve cover. Thanks for the help guys. I actually took the end of a rubber hammer and positioned it on top of the valve cover. Then I tapped the end of the hammer to dislodge the valve cover. It worked well and I did not damage anything. Everything else went pretty well today. I had one mishap with a valve cover bolt. All of them but one came loose. I was able to get it off by hitting the end of the hex socket into the the valve cover bolt because it wouldn't go in there any other way. I had all of the bolts out. After all that I finished the front half of the engine. It took so long to get my valve cover clean but it looks brand new now.
I never thought it would come clean but it did. Now I have to try and clean all of that carbon out of the the intake manifold.
Car of the Moment
1991 Black MTX
K&N Filtercharger
PP Motor Mounts
PP Y-pipe
Rod Shifter
Blazer Tech Fogs
Satchmoz
