VCG: I think I grabbed a set from Summit a while ago before giving a shot to something I'd seen used to restore old gaskets - peppermint oil. Very strong odors, so do it where there's ventilation. Seemed to work ok, I just left them in there way too long, wound up breaking one, which I surgically mended with rtv upon reinstalling (seems to be holding after almost 2 years). Nimz has suggested soaking them in lacquer thinner and removing once you see them start to swell. They will become more fragile so might behoove you to have them on a frying rack or something similar so you can remove them from solution on flat surface. Once removed from solution, let them sit for a while to shrink down a bit before reinstalling. Should be a little more durable at this point, but you still want to baby them until they're seated.
I just did VCG on our Town and Country this weekend and though simpler than the SHO (which I've done twice now), it was way overdue and I just have to clean everything up when I have access to lower intake, wire harnesses, etc.
Wheel bearings:
I'd done my front end a couple years ago and described how I got leverage on the bolts holding bearing to the knuckle. I wasn't using air tools (which makes suspension work MUUUUCH easier), but wise words here:
