Updating 2016 Sync 3
Juicybaka
So I downloaded and installed the latest Sync update which is supposed to have Appleplay?
I’m not seeing this. Voice has changed with few other things. From researching a little, I’m seeing you need to replace usb hub in center console for apple phones to work correctly?
Can anyone confirm 100% before I pull trigger. Thank you.
Lostneye
NY
I do not believe you need to change the hub. Does it have an SD card and RCA inputs or just USB? The USB only is the newer hub and should support carplay.
Roger Batts
Dallas/Ft Worth Area
Correct. For Apple CarPlay to work, you will need to replace your USB hub. After you upgrade to version 2.0 or higher, you need to get part number HC3Z19A387B. That is the upgrade hub for the 2016 model.
Juicybaka
Thank you, I will order now. Any tips to pop existing out?
Roger Batts
I have a hook-up with someone at LKQ for a used one, and I have ForScan. I did my own backup camera install in my old ST, so it shouldn't be too hard!
Lostneye
NY
Let us know how it works out. If I can get the parts for cheap I have a connection to someone who should be able to help me with programming.
Johnbigdog
michigain
There is not a selection in sync 3 for Apple car play like Android auto once you update. One you have the new media hub and connect your phone via U.S.B. with apple car play enabled I think it just popped up.
For us Android people once you update, good to go.
Also. If you do a master reset then connect your phone to Android auto your phone will automatically great a Bluetooth connection. I think it' the same for Apple, but I'm not 100% sure.
