UPDATE!! Python 991 Remote Start / Alarm Install
gurucomputers
Everett, WA
I am installing a Python 991 remote start / alarm on my 94 ATX. I have done a lot of poking around to find the proper wire colors and locations to integrate the alarm harness(s) with the car. Messing with the wiring does not scare me a bit. I used to be a commercial aircraft electrician for Boeing. Most say leave it to a professional. Not this time, I want to do it and learn from it. This is the first time however I have attempted an Alarm system on a car. I am just looking for you all to check the wire colors (In Bold Below) and verify they are going to the proper alarm harness wires. The guide that came with the alarm is worthless. It only has what each wire is for (Not in Bold Below).
I will do a write up as I install it and post it on the forum for future reference.
Thanks in advance.
Main Alarm Harness
H1/1 Red/White Trunk Release Pin 85 on relay (200ma Max)
Purple/Yellow - Keyless Module (Relay May Be Required)
H1/2 Red (+) 12vdc Constant Input
Yellow - Ignition Switch Harness
H1/4 White/Brown Parking Light Isolation Wire
Brown - Headlight Switch
H1/6 Violet (+) Door Trigger Input
Black/Light Blue (+) - Driver's Kick Panel
H1/7 Blue (-) Trunk Pin / Instant Trigger Input
Not Used
H1/8 Green (-) Door Trigger Input
Not Used
H1/9 Black/White (-) Dome Light Supervisor Output (200mA Max)
H1/10 White/Blue (-) Remote Start / Turbo Timer Input
Not Used
H1/11 White Parking Light Output
H1/12 Orange Ground When Armed Output (500mA Max)
Not Used
Remote Start Harness
H3/1 Pink (+) Ignition 1 Input / Output
Red/Light Green - Ignition Switch Harness
H3/2 Red/White (87) Flex Relay Input (30A Fused)
H3/3 Orange (+) 12vdc Accesory Ignition Wire
Grey/Yellow - Ignition Switch Harness
H3/4 Violet Starter Side of Starter Wire on Ignition
White/Pink - Ignition Switch Harness
H3/5 Green Key Side of Starter Wire on Ignition
H3/6 Red/White Ignition 1 Input (30A Fused
H3/7 Pink/White (30) Flex Relay Output
Black/Green - Ignition Switch Harness
H3/8 Pink/Black (87a) Flex Relay Input
Not Used
H3/9 Red/Black Accessory / Starter Relay Input (30A Fused)
Yellow -Ignition Switch Harness
Door Lock Harness
1 Blue (-) Unlock Output (500mA Max)
Pink/Light Green -Driver's Kick Panel
2 Empty Not Used
Not Used
3 Green (+) Lock Output (500mA Max)
Pink/Yellow -Driver's Kick Panel
Racer X
SHO Pilot, Retired
Connecticut
You will need a relay for the trunk release. Otherwise you can look forward to frying your Alarm ECU after the 3rd or 4th time you open the trunk with the remote.
Also, on the parking light wire, I ended up using another wire you will find near the Autolamp switch... I can't recall the color, but if you can wait a week I can look at my install and let you know the wire. For whatever reason, the brown wire wasn't working for me.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
I changed my door switch over to use the dome light. Pushing the keyless, touching a door handle will all set it off on mine. :) I also love mercury switches for those 'ground triggers'.
shoon
cliTaurus
Dawson Creek, BC
x2 on the relay for the trunk release. IIRC the only additional relay I used in my setup was for the trunk.
Skimming through schematics now...
For your ignition feed for the remote start, be aware there are 2 separate 60 amp fuses. 4 yellow wires are joined up on one circuit, and 1 wire is isolated on its own circuit.
Don't tripple everything up on the 1 wire. It looks like all the accessories B1, B2, B3, B5 (should be labeled on ignition switch connector) are all one circuit, and B4 is the yellow wire used for starting that is on its own separate circuit. As for why they used yellow for all 5 wires I have no clue.
I'll keep skimming through and see if I find anything else.
Edit #1:
Cut White/pink wire in half and connect as noted:
Edit #2
You will have 3 Gry/Yel wires coming off the ignition switch. A2 and A4 are critical accessories joined together, and A3 is an ABS power relay. Make sure you connect to either the wire on A2 or A4.
gurucomputers
Everett, WA
Edit #1:
For starter side of circuit should be Red/Lt Blue
Edit #2
Thanks for the info. I ordered an EVTM from Helm but it hasn't arrived yet. Going to pull the column cover off tomorrow and take a visual on the wires and DVM some stuff out.
gurucomputers
Everett, WA
I want mine to go off if the door handle is pulled or someone starts pushing my buttons. LOL
I'm looking to see if there is a way to use the "WARN" function on the door handle and keypad.
shoon
cliTaurus
Dawson Creek, BC
Np.
Apologies,
I just double checked something and realized that you can use the white/pink wire for both connections, you just need to cut the white/pink wire in half, and hook the wires up as noted below:
It cuts your starter wire in half so that if someone attempts to punch your ignition they will be unable to start your car until the alarm is disarmed and the relay flipped on.
gurucomputers
Everett, WA
Well I got most of the alarm installed today. Would have had it completed but ran in to one snag. For some strange reason the DEI 520T backup battery module is triggering the alarm on remote start. As soon as the starter goes to crank the alarm sounds and shuts down the start process.
I have it temporarily fixed by disconnecting the (-) trigger from the battery module to the alarm. It needs to be corrected cause it is the trigger that tells the alarm main power has been disconnected and turns on the backup battery so the alarm will continue to sound.
Any ideas as to why this is happening. The battery is a simple install.
Here is the link for the battery install http://www.the12volt.com/installbay/downloads.asp?srch=all&term=DEI+520t
Still need to hook up the trunk release and the supervisor dome light. Once all is completed and functioning properly I am going to get the write up posted.
gurucomputers
Everett, WA
Well the alarm is installed and everything is functioning as it should. Figured out the backup battery issue. The battery must be fully charged before it will function properly. Takes about 3-4 hours for it to charge. The only thing left is to install the mercury switches (Thanks Eric VerValin) for the hood and trunk. They are on order and should be here soon.
Going to get started on the write up and should have it done and posted by Monday.
