MO-KAN SHO
Okay, I posted on here a week ago about losing the bottom row of gears, and now I have more info.
I now have the car up on ramps and have been underneath it. We (my father and I) believe at one point a clutch job was performed, and whoever did it lost the bolt that holds the rod shifter to the tranny. They then replaced it with a shorter one that eventually worked its way out, cuss so I am trying to find a bolt that will go all the way into the threaded housing. I can't find this bolt anywhere including the ford dealer. Ford apparently only sold this bolt with a complete shift rod, AND the part is naturally obsolete.
I know the bolt is hardened steel 10.9 grade, 12mm diamater by 1.75mm thread pitch, and needs to be about 175mm (7") long. (The one that was in there is 125mm (5")long.)
Does anyone have any idea of where I might find this bolt??? I have tried every place I could think of for 150 miles and can't find it. headbang Tomorrow I am going to try some more places, but I thought since it's after 5 and can't do anything else today, I'd ask you guys.
Any ideas or help is GREATLY appreciated!!!
