Goulash
I have a 93 ATX with 186,000 miles. I'm trying to change the rod bearings. The car is not cooperating.
First was the exhaust which is supposed to be a pain. It was. In Ohio, we have more salt on the roads than the Dead Sea. Still, I only have to drill out two studs. Not bad.
Starter came out, no sweat. Now I have all the nuts and bolts out of the oil pan and it won't move. Doesn't budge. I know that it should be difficult, but not this hard. I'm wondering if anyone has any techniques or suggestions.
Thusfar I've tried tapping (and then, slightly beating) on the sides with a rubber mallet, prying against the sides with a crowbar (and a piece of wood to prevent damage), and prying against the pry-points with a screwdriver, then a tire-iron. Last straw was breaking the tip of a cheap screwdriver off in between the pan and block, and breaking off one of the pry tabs. It's REALLY stuck.
I've removed 10 pan-block bolts, 2 pan-transmission bolts, and 3 pan-stud nuts. Am I missing anything? Because this is starting to get ridiculous...someone help me before I take a baseball bat to the (already cracked) windshield.
- Justin
- Justin
But considering that most people do rod bearings in the car, then it's actually fairly normal not to do them, but if I had the chance I definitely would.
