digeronimo34
RESCUE SHO
Ok here is what happened. In December i heard a knock on the way to work, this was durring the worst snow storm that we had up here last year. I stoped and called a tow truck but none were avalible due to the storm. I drove it home at about 30 mph for 38 miles. If i did not get above 4 grand in any gear you could not here it. I parked it and was not able to get to it for a few weeks after the storm.
Andrew came over and listened to it and we concluded that it was a chain tentioner. I pulled the intake and valve covers and sure enough the chains had eaten threw the tentioner and there was a lot of play in the chains. I got a set from a member on the forum and started to slowly order other parts that i was going to change wile i had it apart.
i painted the intake and valve covers and got the last of the parts. last week we started to put things back together. (Andrew, Hamal, Fonze and me)
These are the parts that we changed:
timing chain Tensioners
valve cover gaskets
cam seals
Valve Cover Bolt Grommets
re shimmed intake and exhaust cams to factory specks
timing belt
MTX Timing Belt Tensioner
water pump
cps
starter
battery cables
battery
dp plugs
spark plug wires
intake couplers hoses
silicone vacuum lines
intake gaskets
throtle body gasket
water pump
When we got finished it was like one in the morning. We started it up for a min without the acc belts just to see if every thing was ok. It started fine and seemed ok we shut it down for the night.
The next day i finished up, put the belt tentioners and belts back on and fired it back up so it could run for a wile, it had been 6 mounts since it was running.
Now i am having this knock that comes and goes it. I called andrew to see what he thought since we did not hear it that night.
We pulled the intake and valve covers back off and checked that we had done everything correctly and that every thing was tightened to speck. Every thing looked good.. I turned the engine over by had a couple of times and put it back together.
Still the same problem.
Here is what it sounds like.
[YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/z6nnr0kZHbA?hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/z6nnr0kZHbA?hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
[YOUTUBE]<object style="height: 390px; width: 640px"><param name="movie" value="http://www.youtube.com/v/z6nnr0kZHbA?version=3"><param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed src="http://www.youtube.com/v/z6nnr0kZHbA?version=3" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="390"></object>[/YOUTUBE]
The first one is short and the second video is about two min.
As the car gets to operating temp it becomes more frequent.
What do you think it is?
Here are the links if i did that wrong
http://www.youtube.com/watch?v=z6nnr0kZHbA
http://www.youtube.com/watch?v=ZACBbRO8gYM
valve cover gaskets
cam seals
timing belt
water pump
cps
starter
battery cables
battery
dp plugs
spark plug wires
intake gaskets
throtle body gasket
water pump
