Uhoh 92
Sammy~D
Wrench Whore
Anoka, Minnesota
well i started the 92 today for the first time in a few months (just to get things moving) and it started and died a few times and now its chugging a bit at idle and being real sloppy what do you think it could be?
89SHO X2
Wa
could be a lot of things. check and clean the maf sensor. also does it rev good? maybe the IAC is sticking. check those first along with a few plugs to see haow they are. anymore troubleshooting let me know.
89SHO X2
Wa
also check the fuel pressure. does the pump make any sounds when you turn the key on?
Sammy~D
Wrench Whore
Anoka, Minnesota
it has new plugs wires and fuel pump and revs great its just at low idle ithat i kills out.... so to night ill check the maf and iac
89SHO X2
Wa
IAC most likely and check the idle screw to make sure the throttle position is set to the right rpm at idle. dissconnect the battery though before. i had similar problems with my other car.
