Denny
Taurus Homeland
D'oh!
I went to the strip last night, hoping to make some nice runs for once. And I'm lined up at the light. Stage myself and then I start to launch. I was simply going to press the gas pedal a bit to get my revs up. The second I touched the gas(didn't floor it or anything, just touched the gas normally) I heard a slight little pop. Didn't think anything until I tried to start. . . .
I didn't move anywhere. So I got out of gear, went back to first and tried it again, thinking maybe I was just out of gear or something. No go. Tried just dropping the clutch, nothing... So I tried reverse, nothing.
Well, so the two guys doing the bleachbox push me out as a crowd laughs at some guy break down in his Taurus at the start.
I check things out. My passenger side axle is busted. The metal part broke inside the inner CV joint, the boot is exposed, grease everywhere, I find the boot ring all twisted up on the subframe.
Question is, is it just the axle or something else?
The other side(driver's) is good from I can tell. However, when the car is in gear, the wheels are not locked. I can turn them both. However, the axle on the passenger side hits and makes a nice noise to it. And in gear, with the car running, if I'm off the clutch, I don't stall out. The engine revs up a bit slowly, and the speedo registers. In fact I was doing "25mph" when I tried to get out of the light. So why isn't my driver's side wheel doing anything? Or is this an effect of the open differential, the power's going to the wheel with least resistance, which in this case is now simply a metal piece that was once connected to the passenger wheel?
The axle is under warranty, however it won't be delivered until Wednesday most likely. According to the repair manual, I need to replace some bolts too that attach to the lower control arm?
Is this an easy thing to do, swap axles. I hear Mark Nunnelly brings SPARES to the track, maybe I'll have to that too!
But just how do I put them on?
Any help would be appreciated. Thanks!
