two questions....
fast-r-sho
valdosta,GA
im getting an airbag fault(9 blinks)what does that mean?
also after long periods of driving,like on the interstate,when i get of the car sputters and then shuts off...then when i turn it off and turn it back on it just makes areally loud hum from the fuel pump. Is that a sign of a bad fuel pump or is there another underlying problem?
fricker66
No help on the airbag fault, but I had similar issues on the fuel pump as you are experiencing. Just had a local mechanic install the 195lph pump that everyone here recommends. Problems went away! Do a quick search on other fuel pump threads. Also, see the shotimes.com article on installing a fuel pump in case you want to do this yourself.
Frederick Ricker
89 SHO
Mostly Stock w/ Slicers
The SHOtimes site (http://216.92.187.145) shows the air bag diagnostic codes. The code "9" is defined as "Primary crash sensor circuit - open or high resistence."
The description of the fuel pump condition was less than clear, but it could very well be a worn out fuel pump. When you turn the ignition key to ON (not START) and the fuel pump spins for a couple of seconds, does it sound like it is struggling? Have you received any CHECK ENGINE lights? That may give you more help to diagnose the condition.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
[This message has been edited by sdpatt (edited 11-27-2001).]
fast-r-sho
valdosta,GA
well when i turn the key to the the on positin the fuel pump makes a different humming noise...it seems to be more louder,and if i let it sit for an hour or two when i turn it back to the on positin the fuel pump sounds fine and it runs perfect,does that help to clarify anything?... thanx
fricker66
I know sdpatt can offer much better technical advice but again, you are describing similar experiences that I had last week. If it was a cold start, I had no problems. When I would start it after driving for 15-20 minutes, I could hear a straining noise out of the rear of the car. Also felt like I noticed a loss of power. New pump and the problems have disappeared.
fast-r-sho
valdosta,GA
Well i have definately decided to replace the fuel pump,thats sounds logical.Hope it works...thanx
fricker66
Here's the website of where I purchased my fuel pump, http://www.autoperformanceengineering.com/
Part number FPF001. The wiring harness does not match up so the wires will need to be spliced. Other than that, it fit right in!
Hope this helps!
Frederick Ricker
89 SHO w/ 78,000 mi
