Tweecer reporting only HEGO2 operating?
jruppert
Big Rapids, Mi
When I datalog with tweecer the tuner shows HEGO2 switching but HEGO1 remains dead. Also, the KAMRF 1 shows 2.500 (or something close) and KAMRF 2 shows it changing appropriately. What gives? I replaced these sensors back in August. Could one be bad? I am not seeing anywhere in scalors where it could accidently be turned off.
Axianator
I am a banana!
Roanoke, TX
There is nothing wrong with your HEGOs. The strange readings you are seeing are the result of improper mapping to the wrong areas of the factory D4U1 code, a well-known problem which will be fixed with the next software upgrade. ;)
Axianator
I am a banana!
Roanoke, TX
drivinhard
Gainesville, GA
I get the same using the sneec datalogger and a 93 PCM (HZ1 or whatever the heck the non D4U1 ATX unit is)
