Turn Signal Issues
Spring Hill, FL
Okay, I've recently developed a turn signal issue, on occasion the relay just stops clicking. A good smack of the dash and all is well again, sometimes it only clicks once and stops but usually I can get it working and it lasts from an hour to days at a time. I replaced the MFS a while back as well so I've ruled that out, it works great. But today when I replaced the stock flasher with a Tridon Flasher only the hazards functioned, the turn signals and I believe the alarm couldn't activate the lights. Since I was still in the Advance Auto parking lot I just plugged the old one back in and returned the Tridon unit. Has anyone had any problems with these units or is the Advance Auto and Rock Auto computer wrong about which one I am to use? Thanks :thankyou:
lowc
aka vapah lock
Quincy, massachusettes
did the dash smack work with the new flasher? if so i would say you have a loose connection in there. if not then i would try a different flasher maybe got a junk one:shrug:
