turbo upgrades
FighAsHuck
Reno, NV
Without Ethanol, there's always the option of going full ****** with METHANOL!
WOOOOOOOOOOO BOY!
REEEEEEEEEEEEEE!!
I LOVE METH!
E85 would be easier, but methanol is plentiful and E85 is not where I'm at. Car still put down 400hp so I have no complaints.
stripSHO
Idiot Savant
Detroit
The difference in VE from 5000 RPM to 6000 RPM is maybe 5%, nowhere near an explanation for the amount of freefall exhibited with the GH turbos. So no it's not the cams. Since I have to guess the real answer I'll say excessive exhaust manifold pressure causing exhaust valve float.
ATP's have made upwards of 450 lb-ft all the way at 6500 RPM, meaning you can make 550 hp with hardly any more torque than a basic tune. I don't know why you guys have started rating a turbos performance based on its ability to break an engine. Stock turbos can do that too if that's what you're after.
The GH intercooler actually makes a huge difference.
Not on my car......mine had really bad boost taper in the high rpms, WGDC had to be maxed to make up the difference, and it make less power with significantly colder IAT's.
Put my stock IC back in with my Ice Water DIY sprayer. My car is going .3 tenths faster in the same ambient air with more boost, less WGDC, and hotter IAT's.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
interesting.
mattr66
Okay.... have you ever seen an ecoboost with lightly ported heads and reground cams all else being equal? Once you see how much duration we don't have you will realize the truth.
interesting.
Not really. Matt said the GH IC is on the verge of being too big for the stock turbos. My turbos were already tired and not making the boost others have with the stock IC.
The GH IC just made my turbo problem worse. It did make the 1 less hp but with 2 psi of boost less. So it is efficient.
Zpak
Es Aich Oh!
The region, Indiana
From my untrained eye it was a huge benefit. Outside of any other knowledge of in tune particulars, with the only change being the intercooler and to be fair, 10° cooler ambient temps, went from a best of 12.1 to an 11.9. By the end of the 11.9 run I was able to hold 5° more timing than the 12.1 which ultimately netted me almost 3 mph faster trap speed.
76FoMoCo
Nampa, ID
I did find the GH ic increased my WG at 17 psi was maxed at 100% on stock turbos. on the stock ic I was 90% now with the bigger gen 3 and the Ic i'm at 70% at 18 psi some of this is my DA runs 2500 at best to 5500 most times
stripSHO
Idiot Savant
Detroit
Okay....
Yeah. 248 degrees total, right? Have you ever seen an NA 3.5l with THE EXACT SAME DURATION rev to 6800 rpm from the factory?
Here's what the power band of these engines looks like when not choked by an almost 3:1 backpressure ratio:
Upload 2020 11 16 19 29 7
(https://www.knfilters.com/dynocharts/69-3528TS_dyno.pdf)
Here's the ECU torque model from my 93 tune only losing 12 hp between 5k and 6k rpm despite a 2 psi boost loss:
Upload 2020 11 16 20 1 34
Now virtual dyno from 3 different tunes showing flat horsepower between 5k and 6k despite that same 2 psi boost loss:
Upload 2020 11 16 20 5 16
The inherent volumetric efficiency of the engine seems pretty simple to estimate from a log as long as the speed density is accurate. VE = Load x (barometric pressure/manifold pressure), no? Here's an example with this 4th gear 4600-5864 rpm data from a run. 3.7% drop from 5000 to 5864 rpm; only 2.5% from 5500-5864 rpm.
Upload 2020 11 17 8 1 20
So I hope you can understand why I find it so peculiar and interesting that dyno runs featuring your turbos are uniquely shaped like this:
Upload 2020 11 17 8 4 28
whereas the competition can carry power to 6500 rpm, like this:
Upload 2020 11 17 8 34 44
Losing 20-25% torque in this span of 500 rpm is definitely not characteristic of the cams. All evidence is to the contrary. That 7 at the end of your tach wasn't just put there for good luck. So let me translate my harebrained theory into a question: what exhaust manifold pressure should be expected with your turbos at 20 psi and 5500 rpm?
DadMobile
Texas
I’ve heard great things about those CR turbos in other platforms. They supposedly have a good compressor wheel design. Either turbo you choose will have enough powah to bend a rod, blow your trans, grenade the rdu/ptu.
Jordan_R
Missouri
Doesn’t cr also offer a stage 3 now? Wondering if it is comparable to the GH turbos?
https://crpengineering.com/product/3-035-310/
CR only upgrades compressor side so you have the huge turbine restriction. 40.6mm compressor is the same size as the GH gen3 turbos except GH matches the turbine side so you have a more efficient turbo. I've seen a car rod the motor with the CR stage 3 though so they do put out some steam just for the price you can get a more effective overall turbo from GH and be less prone to turbine housing cracks from a turbine that can move the exhaust more efficiently. A lot of cost from CR for half the machine work
DadMobile
Texas
Yah it’s kind of a crazy how much those turbos cost. A little birdy told me they have to order $200k worth of compressor wheels at a time. Sheesh
mattr66
Okay....
I could extract a little more power at higher rpms, but there is a reason the factory tapers boost off slightly before the shift the same way that I do.
Sent from my motorola edge plus using Tapatalk
mattr66
Okay....
The NA engines also have the advantage of twin VCT. We can't phase our exhaust cams :(
shootinirons
