Turbo Pulsing
Mark F.
I got my 2013 SHO a year ago and the only mod I've done is add a K&N cold air intake, it's been great so far. On the way home from work the other day I noticed some pulsing about 1500 RPM on gradual acceleration, or if I give it gas at that RPM about 55 MPH. It also seems to dumping the blow off valve before it's supposed to. Like if I give it gas hard I hear the woosh of the air going through the intake then it releases when I let off. It doesn't do that all the time and sometimes it doesn't feel like the turbo does much at all, I hear a lot of air noise (no turbo sound) and it revs really high and doesn't accelerate like it's supposed too.
Before I take it in, what do you think this might be? I think it *might* be a bad blow off valve (if that's what it's called), but I don't know for sure. I did some searching, but came up empty.
glockcoma
Also check connections at the turbos outlet.
The rubber bellows rip, just looking at them doesn't always give it away.
You really need to get your fingers on them.
Mark F.
Thank you so much! That was the problem. It was the small hose that connects to the plastic duct in top circle, ironically it's the connection without a clamp. I popped it back on and got about a mile down the road before it came off again. I put a clamp on it this time, the hose is stretched enough that it didn't want to stay on the barb.
Nice username BTW, I have a bit of a Glockcoma problem myself, some .40 or 9mm usually takes care of it.
shootinirons
