somedude_001
i used to play CS back when i had time to do stuff. but now i drive a boosted SHO so i'm either putting gas init or working to afford gas.
HotRodKid said:
Axianator said:Lookin' good, Alex!![]()
It is just me or does that FPS tranny seem to slip a little on the 1-2 at WOT?
SHO Dude said:Just think what the stock tranny would do when you pour 400hp into it...
Sounded just about right to me. Remember, there's a stall converter in there too.
Yes, but I figured your "bulletproof" trannies would shift faster than what I saw in his video. OTOH, I've always felt that it's better to leave shift firmness adjustments to the end-user rather than use a "one size fits all" firmness strategy straight out-of-the-box.SHO Dude said:Just think what the stock tranny would do when you pour 400hp into it...
Maybe so, but the converter (and it's stall) has nothing to do with how fast the tranny shifts at WOT.SHO Dude said:Remember, there's a stall converter in there too.
Gotcha.somedude_001 said:the line pressure is not highenough to handle the HP i'm making. I have it set at 35psi at WOT so I called FPS and asked how high i could take it. they said to keep bumping it up 5 psi untill i'm satisfied.
'charged ATXs don't even "WHOOOSH" between shifts, just when you let off. how are ricers going to know your car is boosted!?!
While the Engine Torque table is utilized by the EEC for most of it's torque calculations, most of these calculations are only used by the '93-'95 ATX calibrations for computing line pressure and other transmission-related variables.somedude_001 said:would adjusting the torque tables affect the engine's tune? or is this a transmission torque table?
Since you don't have access to any of the converter functions or parameters with the latest version of the TwEECer software, I find it somewhat unlikely that your lockup problem actually lies with the contents of your program.somedude_001 said:also the TC does not like to stay locked on the highway. this has been a issue that the car has had for about 3 trannies (3 years) so i know it in the programing somewhere. also it unlocks the TC early durring tip in which is very anoying.
The values displayed in the Engine Torque table indicate engine torque at MBT (Maximum Brake Torque, or the amount of spark advance required to achieve maximum torque for a given RPM) and are displayed in lb/ft.somedude_001 said:the numbers your asking me to change, what do they represent.
The X-axis (columns) represents normalized engine speed (RPM) whereas the Y-axis (rows) represents normalized engine load.somedude_001 said:what do X and Y represent on that graph (obviously X is RPM)
Simple.1slickRED89 said:'charged ATXs don't even "WHOOOSH" between shifts, just when you let off. how are ricers going to know your car is boosted!?!
somedude_001 said:so tomorrows priority will be to get a check valve so we arn't pressureizing the crankcase anymore.
Lupo said:For now, I would recommend simply letting the crankcase and valvecover PCV ports breath freely. It's not ideal, but it's safe.
Even with a checkvalve to not pressurize the crankcase, the crankcase still needs to vent pressure out at WOT, epecially with boost creating more blowby. It is possible that you can still blow out your oil seals even with the checkvalves in place.
Just tee the 2 ports to a small breather.
somedude_001 said:after a couple of hard pulls the car smells like a gas leak and the breather is dripping what seems to be fuel vapor... oh well i guess that what i get for runninga 218K (i hit 218K the other day) engine with boost..
