So I got a tune from one of the popular guys online. I installed the tune right after a rebuild. The car never ran 100 percent correct. Looking into the tune on the sct it says the axle ratio is 2. Something but it's really 3.16. Will this difference cause any issues
Hey Buddy,
I have 13, Non PP. Only “Modifications” are a K&N drop in air filter and Power Stop drilled & slotted rotors and performance pass all around. I do have a tune from Brad for 91 Octane. His tune is fantastic and my car runs Great. The acceleration is quick and smooth and the shifts are crisp but not jerky or rough. I love that the gear indicator light is always on. I love it.
Maintenance is crucial! If you take care of these cars, you will avoid major problems. I change oil every 2,500 miles with
Mobil 1 5w-30 and Motorcraft 500s filter. ALWAYS use the OEM filter that are specifically designed for that engine.
Every 5,000 miles, I remove 6 quarts of Motorcraft LV Transmission Fluid and rotate the tires.
Every 10,000 miles I drain one (1) quarts of Coolant and add one (1) gallon if fresh coolant.
Every 20,000 miles I change the PTU fluid. It is a pain but totally worth it. I have used Redline Shockproof and
Mobil 1 75-140.
I changed the spark plugs when I first bought the car. It had 65,000 mikes. It has 92,500 now and at 95,000, I will change the plugs again. Not because it needs it but just because I want to.
I know this is total overkill but I love working on it and so far so good.
Go with Brad @AJTurbo for a tune and you won’t be sorry. Enjoy your SHO, they are great cars.
