True HID...
Blast7
Rochester, NY
Fred, a guy over at the SHOtimes Forum has these. I want to say his name is SHOBOB but I will go and check. As of right now I am not sure what kind they are. Also, last I heard there were only true HID's for the 9004 bulbs which are for 1st Gens. At least I think the 1st Gen's have the 9004's.
1991 Black MTX
K&N Filtercharger
PP Motor Mounts
Rod Shifter
Blazer Tech Fogs
Want to Buy:
~1st Gen Black rust free trunklid
~1st Gen Black rust free front door mouldings
SHOed_up
Ann Arbor, Michigan
I was at the SVT/SHO meet and saw both a contour and SHO with HID's. The SHO HID's were donated by a late model lincoln LS in a boneyard. You can bet I'm gonna be dropping by the yard on monday to search through their lincolns, mark 8's, LS's, Nav's, and continental's. It sounds like the perfect Cheap HID, they took a few seconds to warm up but once they were going it was BRIGHT!
SnoSho
Circle Pines, MN, USA
Did he say how much work it was to get the stuff in there? I'm just assuming it's not a nice snap together operation unless the newer Mark 8's had the same size lights old ones had "real" glass that would replace gen2 wraparound plastic as I recall.
Tim M
ACV1081
Member #187
IA US
I'd like to know more about the Lincoln LS HID swap cause that seems to me like the best/cheapest way to get the job done. Also can the stock headlights handle the power? That would be sweet to have HID!
1004303681370 NEW SHO PIC 102901
~Adam Varney~ mailto:[email protected][email protected]</A>
1993 RED ATX(3 replacements) W/shiftkit, 17" Konig Reigns, 245/45/17 Goodyear F1 Gs, 26mm ASB w/poly bushings, SHOSHOP Cold Air Snorkel W/ K&N Filter.
Not yet installed: 24mm ASB, 70mm MAF, all 60K service items, & rest of the poly bushings. Soon to be G-teched to see where I stand.
S
SHOFF
Guest
The hids that i have in my car(that shoed_up was talking about eariler) are out of a 2002 ls it took very little work to put them in i had them installed in less than 10 minutes the only problem i had was the fact that there was no way of locking them in witch was fixed very easy with mr. epoxy besides that not a problem. One more thing hids are very very bright in the stock housing and people love to flash you, so you need to invent a way to put another buld in some where to defend your self since the hids are on or off on bright or dims
Sho shop cams
80mm mass air
big bore butterflys
underdrive pullys
strut bars, front and rear
cold air intake
high flow y pipe and cads
18 inch quatem tek wheels
eibach springs
2 tvs
dvd
playstation
5000 watt system
www.shoracing.com/pix/g2/donnyc_93sho.jpg
TwiceSHOwn
Atlanta, Ga
Any chance of getting some pics? Of the under the hood stuff.
Also are you saying that you lost your high beams? that these are eithe ron low beam or off?
Thanx
ACV1081
Member #187
IA US
So what do I need from the LS at a boneyard to do this HID setup? Please list parts & what you paid. Thanks.
S
SHOFF
Guest
All you need is the ballast and the bulb i got mine from my friend who test crashes cars at ford i think they run around 200-300 hundred a set at the junk yard. the set i want to see on a show is out of a audi tt coupe that would be sweet
Sho shop cams
80mm mass air
big bore butterflys
underdrive pullys
cold air intake
eibach springs
2 tvs
dvd
playstation
5000 watt system
SHOed_up
Ann Arbor, Michigan
I'm afraid most of the boneyard TT's are in germany from when the early one started flipping like flapjacks. Haven't gotten as many messed up since they stopped flying.
Blast7
Rochester, NY
I finally found out about the HID picture that I posted earlier. It is the Philips kit and the member name at SHOtimes forum is SHObob.
1991 Black MTX
K&N Filtercharger
PP Motor Mounts
Rod Shifter
Blazer Tech Fogs
Want to Buy:
poffffd
