Randall
Hey Guys!
I did an extensive search for code 528 on this forum, and even searched for Steve's (ProjectSHO89) responses as these usually allow me to avoid making a thread, but with this particular code, I am getting nothing.
I have had this code along with a code 219 for a few weeks, and from experience I know 219 usually means the DIS is bad, which I saw yet again as I changed the DIS a few days ago and 219 is no where to be found now when I run the codes, but that stubborn 528 is still there. I know that this code is for a clutch switch, but does that mean AC clutch switch or clutch pedal switch? Either way, I have been getting 17mpg lately although I have not filled up and recalculated since changing the DIS a few days ago that may have been causing the drop in fuel economy. But, I wanted to see if 528 has anything to do with fuel calibrations or even just the running conditions of a SHO engine? I looked in my repair manual, and it defines 528 as a "PNP short or low voltage at pin 30" which makes no sense to me since the booklet that came with my code reader says it is a clutch switch issue.
Anyway, any help here would be great as I went almost an entire year without a single code, and would like to go back to that status!
Thanks!
Thanks!
did you come up with also? Pins 46 & 30 are what goes to the CES (Clutch Engagement Switch) 46 is signal return and the 30 is the input power to switch. so... is it the wiring harness issue? FWIW it is a "continuous code" try to erase them and see if it comes back
