Trashed Trans, you guys'll love this.
redwraith94
Burning River
I bought this Sho from my friend Roger, and knew it needed the trans replaced. I am almost done rebuilding the replacement, and just got around to dismantling the old one.
He did alot of neutral drops, and burnouts, and almost always a drag style launch. I am frankly surprised that the clutch held up so well.
The 1st through 4th gear's blocking rings were each broken into three pieces, The differential had lost a pin, and gear, and last but not least the first gear on the output shaft had crushed the grooves on the shaft, I wasn't even able to get the synchro set off of the output shaft with a gear puller. It was awesome.
The differential with the ejected pin:
The broken blocking rings:
The holes in the transmission case:
Last, but not least, the crushed shaft splines:
I finally figured out how the shaft splines got crushed by first gear. He ran this trans for months after the diff pin was ejected, and the trans got really low on oil a few times.
Since Roger always launched in first with low oil, there wasn't enough for the shaft, and the splines got heat treated. After they softened up the force on first gear smashed them. You can see the little bit of blue from their 'process annealing'.
I showed him the broken blocking rings, and he just said 'that makes sense'...:swing:
Incidentally, this trans had about 217k miles on it, and even with the ejected pins, the pins weren't galled, and neither were the side gears. I think with replacing the roll pins with hardened (grade 8 or better) shoulder bolts, and adding moly to the oil. It may solve the problem of the differential grenading like that. On both sides the roll pins were sheared off, but the aluminum would have stayed in tact if they hadn't broken.
NebraskaSHO
Harumph!
Omaha
Another MTX destroyed.
Someday there will be no more just like the V8 headbolts.
Phoenix
SHOHOLIC
QC , Canada
Holy crap I cant think of a way to do this to a trans....The real question is how the **** he managed to destroy a tranny like that , from top to bottom.
Shoaz
Studly dood
Scottsdale, AZ
You might want to carefully inspect the motor and tranny mounts on that car, too. Drivelines and hub bearings as well.
AREA 91
PA SHO SHOP
Area 91
I have a MTX4 here at my shop that is completely destroyed just like his! Broken blocking rings, chipped teeth, and I had to grind down the main shaft to remove a syncro! Massive destruction!:nut:
redwraith94
Burning River
I guess I misused the term neutral drop. I mean revving to 5 grand, and then shifting into gear while removing ones foot from the clutch petal. Kind of using inertia to get the car going that much quicker...
It is worthless without pics, I will try to get some for you guys this weekend.
I want to know how the **** he flattened the grooves on the output shaft. I can't believe it, it's supposed to be hardened steel...
revhardSHO
Seattle, WA
I was able to drive a 92 with ejected diff pins and huge hole 150 miles with no fluid. I had absolutly no idea until I put it up on a lift to change the oil. When I pulled the case apart it was hard to recognize what was what, but I never had a problem shifting on that trip.
1995SHO9
FLEES ARE COMIN
Carlisle PA
From you?............
HotRodKid
mmmmm ... turbo
Western NY
weld a washer to each end of the pin. job done. extra points if you space the washers up off the aluminium some so the steel and aluminium can expand / contract of their own free will
