transmission
nathan2356
edmonton
I have a 1988 ford taurus and any time I drive it hard the oil from the transmission leaks out. If I drive it moderatetly as long as it doesnot heat up to much it operates ok .Any suggestions as to what is the matter. Thank you.
Mike Kopstain
Arlington Heights, IL
Nate, your best bet is to head over to www.Tauruscarclub.com and post the question over there.
Off the top of my head I would guess that there is a leak in the gasket or you are having some pressure problems. If something in there is blocked you may be getting some serious pressure issues.
