Transmission: this can't be normal
jchaase
Kasson, MN
Watch this video and comment, please.
2011 SHO. 73000 miles. Dry road, about 45 degrees out.
http://youtu.be/bIMjbZSrpbA
Thanks in advance for any advice. Also, after it did this, the power was reduced. After coming to a complete stop and accelerating again, it stayed in first. Shifting to manual mode did NOT illuminate a gear number and the BLIS system reported an error.
Shut off and restart car? Like it never happened. All normal.
WojoMojo
MN WOJO SHO
Minnesota
That video hurt to watch! My only fear with my SHO is the transmission, especially since I'm pushing 100 more hp+tq than stock. Never had this issue though and I'm at 63k. I had terrible experience with my 2011 mustang with the transmission, and it was mostly to do with the computer. Had the adaptive transmission that would adjust to how you drive. Just terrible in my opinion. Had a few sensors replaced (believe 3 solenoids in the transmission) and it fixed 70% of the problem. I've heard from a few places these transmissions are also adaptive and adjust to how you drive. But not sure. I know on my mustang when the transmission was acting up I had to disconnect the battery for 15 mins and that would reset the adaptive transmission and it would feel like new again and shift amazing. I'm no professional with this transmission though and not sure what's wrong. Hope it's just something stupid like the computer or a sensor.
Pull codes, see if you have a P0751 set. Even though this notice is for 2010 vehicles :)
http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=171494
TSB 10-9-9
2010 Ford Taurus 6F50/ 6F55 Transmission—Dtc P0751—Harsh Or No Forward Engagements
FORD: 2010 Taurus, Ford Edge, Ford Flex ISSUE Some 2010 model year Taurus, Flex, MKS, MKT, Edge, MKX vehicles equipped with 6F50/55 transmissions may exhibit DTC P0751 and delayed/harsh or no forward engagements and/or slipping 6-4 or 5-4 downshifts. This may be due to a broken orifice restrictor cup plug in the forward clutch circuit. Affected transmission build dates are 12/11/2009-04/15/2010. The orifice restrictor cup plug sits in the transmission case below the forward clutch feed seal under the main control valve body. ACTION Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE 1. Remove the main control valve body, refer to the Workshop Manual (WSM), Section 307-01. 2. Remove the forward clutch seal. See WSM, Section 307-01 for additional information. 3. Inspect for a broken orifice restrictor cup plug in the forward clutch circuit. a. If no damage is found, continue with normal diagnostic; do not continue with this procedure. b. If orifice restrictor cup plug is broken, continue to Step 4. 4. Remove the transaxle, refer to the WSM, Section 307-01. 5. Disassemble the transaxle, refer to the WSM, Section 307-01. a. Do not remove the bearing cups or seals from the transmission case as the case is to be replaced. b. Do not remove bearings from transfer gear shaft or differential. 6. Inspect the forward clutch piston for damage. Also, look for a small round piece of metal in the clutch area. 7. Replace the transmission case half, clean and reseal transmission. 8. Reassemble the transaxle, refer to the WSM, Section 307-01. 9. Reinstall the transaxle, refer to the WSM, Section 307-01.
Could be related to the symptoms during your test drive. Lurching/clunking. More than likely a combination of valve body (affects line pressures), broken orifice cup and TSS/OSS sensors.
Also, what fuel are you running? See if running premium instead of regular makes a difference. You may have to try multiple brands also, always from a busy station to make sure the gasoline isn't getting stale.
Good luck! May want to take a copy of the TSB with you in any case.
jchaase
Kasson, MN
It's at the dealer... Took tech for a drive and it didn't act up (of course). They'll take it for another romp later and scan it on the fancy scanner. Crossing my fingers!
jchaase
Kasson, MN
Verdict is in.
Power transfer unit failure. Being replaced. Booyah! Sooooo glad I got the extended warranty.
jchaase
Kasson, MN
Tech that went on a drive with me was a fellow SHO guy, he knew all about these cars and the early build transmission issues and tsbs. I'm pretty confident this guy and dealer will make it right. Will know tomorrow when it's done!
I assume that was some kind of buffetting noise? Other than that sounds great! PTU, interesting ...
jchaase
Kasson, MN
Got about a car payment worth of loose change in the center console... That was prob the noise. :)
