Peezys SHO
Im having problems with my 91 sho's 5sd tranny. Sometimes when you shift the car into first it takes a while to catch if you put it in an try to take off to fast sometimes it will pop out or grind, and i cant shift fast either going into gears at high and low rpms reverse seems fairly easy to get into. The fluid is full the clutch has been replaced and flywheel has been replaced within the past couple months, the person i bought it from said its the shift linkage and the cable is stretched out and needs to be replaced i dont know if thats true or if it even makes sense, or maybe the clutch just needs to be adjusted
