transmission ratios
beefcake
cincinnati, ohio
thought it was interesting, i was doing some research today
after the track on friday, i felt like i was going into 5th right after the beams
sure enough
# First Gear Ratio :)1): 4.48
# Second Gear Ratio :)1): 2.87
# Third Gear Ratio :)1): 1.84
# Fourth Gear Ratio :)1): 1.41
# Fifth Gear Ratio :)1): 1.00
# Sixth Gear Ratio :)1): 0.74
# Reverse Ratio :)1): 2.88
1 to 1 is at 5th, not 4th
i just found that interesting
also, the limited awd comes standard with a 3.39 axle ratio
typhoon5000
Ferd Enganear
Shelby, MI
What's even more interesting is how many final drive ratios there are availible (from the Ford Technical Specs page):
Gear Ratios
1st 4.484
2nd 2.872
3rd 1.842
4th 1.414
5th 1.000
6th 0.742
Reverse -2.882
Final drive FWD 2.77/ 3.16, AWD 3.16/ 3.39
And that's just for non-SHO Tauri. The SHO is 2.77 or 3.16 with PP.
I wonder how different an SEL AWD with 3.16 feels compared to the Limited AWD with 3.39?
