transmission problem
totallytuned
WASHINGTON
did anyone filed for lemon law about the transmission harsh bump in 1st to 2nd gear or any tranny problems
shomuchfaster89
MI
I'm sure someone with more info with be along, but I'm pretty sure that if you're talking about the v8 sho, the car is far too old for those complaints to mean anything to Ford.
I don't know of any recall on those trannies, even though they've always had problems. Not sure though.
Usually the problems are resolved by a) checking fluid levels, b) flashing the PCM to get it up to date, or c) modifying the valve body. If you are having transmission issues, I'd get all these fixes applied first before heading for the lemon law.
SHOrod
Torrie Tuned
Cedar Rapids, IA
I had the harshness and the dealer fixed it on the first attempt with a new firmware load and by applying the valve body TSB. That was over a year ago and no problems since.
-Rod
totallytuned
WASHINGTON
Hi again, Thank you for your comments but I actually went to the dealer and perform the TSB 13-04-16' "replaced valve body and separator plate per service manager reprogramed tcm per SB 13-04-16" this been done on my car and I only have 5400 miles only..... What else do I need to do???? need help guys my last option is to lemon it.... coz trading my car will hit me lost of money... 2013 Taurus sho has only trade in value of 27k on our state....
totallytuned
WASHINGTON
Actually all it was been in and out the dealership. " replaced the valve body and separator plate per service manager reprogramed TCM per service bulletin 13-04-16" this been done on my car and still have it.... I need your knowledge about this harshness on shifting. My last option is to lemon it... I was looking around to trade my car but the value of the car is only 27000 max its a 2013 SHO options is the whole nine yards and it has only 5400 miles on it.... need help for any resolution....
Was all work done at the same dealership? I would change dealerships to see if the work was really done properly. That has been an issue in the recent past. Or else, talk to Ford National Customer Service and have someone from Engineering come take a look at it. Since the problem is not "normal", and if the fixes have truly been applied, they should replace the transmission.
I would do as stated above first. Keep in mind that lemon law usually varies by state and a lot of it has to do with 'reasonable' attempts at warranty repairs.
markathome
2010 SHO
VA
Yea, I'm on board with what everyone else has said. You need to make sure they performed the TSB's and validate their work. I would definitely take it to another dealer. They've obviously missed something or done something wrong.
ryanunderwood
Va
I have the bump in my Taurus, my wife has the same bump in her Ford Explorer (non ecoboost 3.5) so I'd definitely equate it to the transmission. We just ignore it as it doesn't happen often and the dealership seemed to think we were nuts when we brought it up.
(meaning we can't recreate it on demand; it just happens when it happens)
Crash712us
Chasing my tail
MI
I did here of someone recently having there car bought back by ford for this issue.
