JRA2000TL
The Complainer
Figured it'd be easier to post than try to search for hours typing in "jerking after letting off gas". Anyway, that's what the 89 does. I know in MTX cars there's some sort of "gear lash"? (is that what it's called?) when you let off the gas; however, about 1/2 a sec. after letting off, it's rather a harsh ****. I've replaced the front motor mount with a NESHO reinforced mount, so that problem has been corrected. What should I check for this symptom?
