transmission flush gone bad
shoteen95
isn't a teen :D
Dearborn Heights, MI
Decided to change the tranny fluid since I don't know if it's ever been done. First i dropped the pan, cleaned it out and changed the filter. Put the pan back on, filled with about 8 quarts of fluid.
Then to flush out the rest, i disconnected the hose from the drivers side of the cooler. Ran a hose from the cooler to a bucket to collect the old stuff, then put a hose on the one that came off the cooler into a bucket of new fluid.
Started the car, and it began to pump out fluid (check)
Then the flow just stopped, and not once did i see the bucket of new fluid get sucked into the system..whats up with that?
SHO SPD
SHO member #480
Naples, Florida
So what happened did new fluid end up being sucked up, you just didnt notice? I would like to try this exact procedure on mine.
