transmision question
Dr_Thompson
CT
at the bottom of the tranny were the oil pain connects to the tranny, should there be a little visible space where you can actutaly see into the tranny. Im installing mine now and i noticed that last night when bolting it in. Everythings bolted in correctly, starter, dust shield, and the oil pan bolts. Its not much space, half an inch maybe, but i can see the flywheel. Is this normal
thanks
Ishodu
There should be only enough space there to get the sheild in there. Make sure you got the tranny on the dowels. These could be holding it back and are about .5 inch.
Mr Anonymous
Tire Wall
Agreed. Something's not lined-up properly. Time to remove all the bolts holding the tranny in and try again. :(
Dr_Thompson
CT
well, the shield does line up with the starter and oil pan holes correctly, then i noticed the gap and was like :eek: that aint right. sooo i guess im gonna have to losen the bolts and try to get it to slide in. Back to the fun! :cool:
Dr_Thompson
CT
<img src="http://64.4.53.250/cgi-bin/getmsg/Mvc-009f.jpg?curmbox=F000000001&a=cb823937036fe7b8c363e6eededfd543"> just checking to see if this pic works
Dr_Thompson
CT
i was actutaly thinking this may be correct, i went to a friends house and peeked at his shos tranny, same thing. The parts of the tranny where the oil pan bolts connects are touching the oil pan. Its like there is an indentation in the transmission.
Dr_Thompson
CT
any more ideas because i think it looks as it should and im gonna start bolting it up soon. Im thinking it looks right and if it isnt then s***
