ShoGuy93
Yes I Have Blue Rims
That is just Great!! Thanks Chris!
Slo-Sho said:You've got your power, your source, and the ground. The sending unit should've came with.
DoC-JoneS said:i agree on the shrink tubing. the wire from the sender to the gauge does not come with the kit.
DoC-JoneS said:autozone asile 2. shrink tube (just ask, it is usually black and looks like very thin rubber tubing) and a variety of stock wire in many colors to match your SHO. personally i'm going black and yellow.
sho 'nuff said:The ignition switch is just one place to tap into for power to the gauge. Because besides power for the light you also need power for the gauge since all the sender wire does is send you a reading of the sending unit.
sho 'nuff said:we found that there is a spot in the fuse box for manual climate control that is unused; so I tapped into that for the power to the gauge itself.
