Trans Shifting problems
North Carolina
Ok went out to my car this morning... and It wouldnt shift into any gears (MTX). I would... with some brutal force move around the shifter pattern and it wouldnt go into any gears.
I consider the fact that this is probably due to the fact that the trans was cold from the changing weather.
But I eventually got it in first, second and reverse... then once it got driving its like it never happened...
Thoughts?
zach44102
BIG TURBO
Georgia
check the fluid....when i did my cv axles i lost a quart or so....well i kinda forgot about it untill yesterday when i had a similer problem and 3rd gear sounds like im running a supercharger..
zach44102
BIG TURBO
Georgia
and if you cant get the plug out put in a 1/2 a quart through the sensor on top of the trans
