Trans leak
hotrodmerc
Virginia
If the VSS is bad and changes trans line pressure can this cause a leak??
I'm getting ready to change the VSS. Sensor and small leak started at the same time.
hotrodmerc
Virginia
Yes it's an ATX. I'm know the sensor is but i'm not sure if it's common to leak around them.
hotrodmerc
Virginia
It looks like the front pump seal is leaking. It only leaks once in a while and seems to leak more when you make a right hand turn.
hotrodmerc
Virginia
Replaced the vss no more leaks runs great again. It took me about 2 1/2 hours to replace. It's quite a bear for no more than it is.
