Okay, here it is! What I pulled out of my trans to oil pan bolt on the MTX:
3/8 X 1.00
Now, that might and might not be what was in there to begin with, but mine went in easy like it came right out of there to begin with. If you want to be safe, go ahead and get both:
M10 X 1.00 & 3/8 X 1.00
The 3/8 is just slightly smaller in diameter than the M10(10mm). So IF it is suppose to be a 3/8 thread, the M10 will be digging in and you don't want that. My 3/8 thread has stayed in longer than the original after a tranny drop.
If you never bought a bolt or don't know measurements of bolts, the sizes I listed are what you'll look for 'exactly' on the cubby boxes of bolt selections. The head size, where the socket goes over, doesn't matter in size. But if your curious, mine is a 14mm with tight fit and some slack with the 9/16.
Good Luck and don't over torque those two bolts as they're easily stripped. I believe the torque rating is like 25 ft.lb. If it's already stripped out in the trans, go get the same thread size, but 1.25 in length to catch remaining thread in the back. Also, it's not a good idea to go ahead and get that size, because if you strip that, your pretty much screwed. thumb
Edit: By the way my bolt is a 5 grade, the one with 3 lines on the bolt head. So that holds up and is proven in my SHO. If you want to be more safe, see if you can get an 8 grade as it has 5 lines. Can't forget this either, it's NOT fine threads. I guess standard threads if that's what you call it, like the others? shrug
<small>[ December 10, 2003, 03:44 PM: Message edited by: TYSHO ]</small>
