tranny swap
zerg1024
NJ
does anyone know if u could swap an automatic tranny from a 3.2 to a manual from a 3.0 car?
SHOguy 92
Duluth, MN
Are you asking if you can make an ATX SHO into an MTX? If so the answer is most defineatly yes, but it isn't too easy. Here i will give you the copy of an ad posted in SHOclub's classified's call this number and talk to this guy.
89-95 ATX-MTX kit, low mile MTX, subframe, brackets, all the wiring harnesses,and much more, instructions from the first person to do the conversion.$1200 Craig Smith, Austin, TX. 512-707-8760
Good Luck with the conversion I hope you've had some "under hood" time you'll need it.
Joe_SHO
ND
Is this guy still in business? Does he actually do the swap or just give instructions? I want a 5-speed soooo bad but I'm definitely too intimidated to try it myself. With my luck I'd begin and eff something up and wind up worse than I started.
Certainly no one can say I didn't run a search this time :p
crystizel
