SHOfun 93
Well this is twice this has happened in the past month or so. I went to the track tonight, and the SHO shifted like a champ all night, no burnouts, and seemed fine. On the drive home ( the track is about 20 miles from my house) the SHO started to buck, lose gear, and only shift into 2nd at the highest. I pulled over and fortunately a friend who was at the track saw me and followed me into town as I just kept it in 2nd on the shifter to prevent it from trying to shift into 3rd and slip in and out. I thought for sure this time the tranny has let go. However, when the tranny cooled a bit, it shifted up into 3rd and then I was able to drive it home at a better rate. I babied it home and let it sit, pondering wether to even trailer it back to Dallas (again) or to keep on driving and bite the bullet for a Doug Lewis special.
Three hours later, after doing a lot of thinking, I decided to see how she was shifting. I got out of bed, went out to the car started her up and wanted to see if I could even get something up to 3rd for using around town. I checked the tranny fluid, it had a burnt smell, but stil appeared a nice red color, not black. Hmmmm oh well, I might as well see if it will shift worth a dang, so just a bit ago, I took her for a spin and was pleasantly surprised that the car shifted like a CHAMP! IT EVEN FOUND OD! I got brave and really got on it from a stop and it found all the gears like clockwork!
Here's my question. Can the tranny fluid get so hot, that it loses viscosity to the point where it won't shift? To the point where after it cools, it shifts again? If there was gear damage, or if the OD band was shot, it wouldn't be able to find it again, (trust me I know) but my buddy said that there wasn't any black smoke following me (that is what happened the last 2 times I dropped trannys) and all it did was slip and slide around trying to find gears. After cooling, it shifted fine again. Should I flush and switch to synthetic to be more temperature stable? Some have said that a flush will send the tranny out the door for good, but if there was indeed gear damage, it wouldn't be shifting as good as it does now. I think it just needs some more temperature stable lubrication. Let me know what you guys think..
<small>[ August 04, 2002, 04:10 AM: Message edited by: Jeremy Hohn ]</small>
