TPS Problem .......
Vsho93
Milwaukee
I have a 93 ATX , replaced the tps just as the car died due to crank cancer, I just got the car back and it has no throttle response at all!!!! Everything motor wise checks out but I have a feeling about the tps , I had to reorder it cause autozone sold me the wrong one... turns out my atx had an mtx tps sensor originally ( from a 92 but that was my build date ) and it operated perfectly until I put the atx version on ? I even checked voltage does not work at all, anyone here knows if replacing that sensor properly will bring back throttle response? also an mtx tps on an atx?
example if I'm at 30mph and stomp it the car will not down shift and just slowly builds up speed same goes from a stand still , I'll floor it and the car will go slowly then build up speed still shifts fine, transmission was replaced 12,000 miles ago and worked absolutely flawless.
Btw: check engine light is on , have not had a chance to pull codes
justin mccluske
washington
test it with a meter by putting the ground lead on the battery nagative and the positive lead in the middle pin on the tps , turn key on and see if you got voltage and if it goes up smoothly as you turn the throttle up . you should see .97 (should be at idle) and 4.5 -5 v max (wot)
Vsho93
Milwaukee
the old one has dead spots , new one reads all over the place no where near the .96v , will have a new one tomorrow just hoping this could be the culprit and I don't have another issue
SASHO91
Zoom Zoom
San Antonio,TX
the EEC will learn the idle voltage, so it's not important to get the idle voltage as close to 1v as you can... just bolt it in a go.
Vsho93
Milwaukee
awsome , will try again tomorrow , just curious is there anything else that could cause the symptoms I have above?
btw I also replaced cps, crank sensor , both o2 sensors, dis, maf, idle air control valve, air tempature sensor, fuel pump and filter, new cats, coil , wire set , plugs .
SASHO91
Zoom Zoom
San Antonio,TX
I would check the wiring harness at the EEC.. Just fixed a car that had kinda the same issues you are having... found out that a couple pins on the harness @ the EEC were out...
Just another place to look.
Also, I have been given bad new parts... so don't rule that out yet either.
Vsho93
Milwaukee
just pulled the codes this morning :
123 TP is/was high or short to power - TPS
The car will not give me a 111 code so I can run the KOER test , but so far all I get is 123
Vsho93
Milwaukee
I just got back put the new sensor in , reset ecu and all I can say is she's back , runs how she should , now to go buy a cat-back and rims , appreciate all the suggestions
hawkeye18
Sorta cares
Norfolk, VA
glad she's back on the road! :thumb: sorry I didn't see this earlier or I would've also said to get a new TPS. I have seen more than one bad from the factory. You can't ever assume new parts are good!
Vsho93
Milwaukee
you're not kidding , this is my 3rd "new" sensor lol
