ManySHOs
I plan on putting my car back together in the next few days after catching a slightly worn woodruff key before it caused any major problems. I'm very concerned about torquing the crank pulley bolt to spec or higher now that I've had this issue. I do not have a flywheel holder tool nor do I feel like removing my starter to use one.
I was thinking of removing a spark plug and inserting a long bolt into the combustion chamber to stop the engine from rotating while torquing the bolt. Does this seem like a good idea? I can't imagine that this would cause any damage to the piston or would it? I wonder if I can get a nylon tipped bolt that size to use...
Thoughts?
Ian
Thoughts?
Ian
