Head bolt torque specs
99sho-time
Hello so I had built an engine and im getting ready to put it in and iw as just reviewing things. I noticed in the book i used it told me to torque the head bolts to 20-23 lb-ft then rotate an additional 85-95 degrees. This is what the book told me at the time. This seems awfully loose? i tried to find other sources with the head bolt specs but failed anybody else seen these specs anywhere?
Texas Marauder
Lone Star State
That is the correct procedure. Final torque is probably 75-80 lb-ft. A good angle torque wrench will tell you the final torque. Torque and turn gives a more consistent torque value than single stage torquing.
