Torque Braces?
1992SHOMTX
Vrrooommm...pssshhhh
Providence, RI
Does anyone make a torque brace for the v8s? Basically the torque brace goes from the engine to the trans/body and eliminates wheel hop. I was just wondering because i was browsing the Redline forum and they have them and work beautifully...so i was just wondering if they made them for our cars or not...
LJRuddy
Pop lock n drop
Poaceae fields
You talking about subframe connectors? I dont think anyone makes them for a Gen 3. Maybe a Gen 1-2 could be adapted to work? I dunno.
SHOGrabber
Lima,OH
I'm a little confused myself on that question? :nut:
Are you talkin about a engine torque strap? :shrug:
Porkchop
The Black Sheep
Virginia
Torque strap, torque limiter same thing.
Its similar to the tricks used by the v6 guys.
1992SHOMTX
Providence, RI
im not really sure what to call it...they call them torque braces...ill show you a pic... and i was kinda wrond...it goes from the TAM(top axis mount...basically the top motor mount) to the radiator support and strut tower...
Torquebrace
its the two silver "shocks" that are attached to the motor mount. Ive heard good reviews on them and am gonna try them out on my RL but i was wondering if we actually have them for the G3s because the wheel hop sucks....bad
and yes they make SFBs for the g3s also...at least im pretty sure..
MotorMouth
Love that V8!
Lakeville, Mn.
If you want one there is a cheeper alternative to the one that you seen on RedLine Forums (goofyguy, on RLForums came up with that set up). I just went and bought a set of sway bar end links off of a 1999 to current chevy 4x4 truck. Worked great. Wheel hop on the RL's is friggin horrible. I about lost a filling the first time I had it happen. I've since sold that heap, I had nothing but problmes with it, only had 8500 miles and was in the shop for warranty stuff 11 times :doh: .
Here is a pic of the bracket I welded up for the sway bar end link on my RL. Only cost 25.00 for this set up, if you have a budget in mind....
Is wheel hop an issue with the SHO? I guess I have never made a hard launch with mine so I'm not sure....
1992SHOMTX
Providence, RI
i dont know about anyone elses but yeah wheel hop is a bish with mine..maybe because im all stock except no mufflers...haha
i havent had and problems with my rl...it has around 25k on it and has been to the dealer 3 times for warranty stuff...(crank sensor ignition and seat cover)
EDIT: i think i know who you are...i think i asked if you welded the cams on your v8 :rofl:
Mr Anonymous
Tire Wall
Chris, are you running smaller tires than stock? That's really the only time wheel hop becomes an issue with these cars. The motors in these cars really don't move too much compared to most, and with reinforced motor mounts they barely move at all, essentially eliminating the need to fabricate additional dampening.
Jonny Cash
Good boy
Hollywood, FL
Well my motor most definitly moves alot :oops:
1992SHOMTX
Providence, RI
actually im running slicers on the car for the time being...until i sell the g2 because the slicers have better/new tires. So yeah im running smaller than stock. I dont have reinforced mm's either so that could be something to look for...btw chris...pm me i have to talk to you about something we talked about a few days after i left the shop :thumb:
That's a heat shield I made out of a hose clamp and a piece of SS. Here's a shot form the back side.
ES96SHO
SHOtime96
West Lawn, PA
Paul, you are still definitely the most innovative and meticulous GenIII owner!
The thing I can't believe is that you're missing the one of the Trans to Engine bolts.... What's up with that?
