too much?
pudge235
CT
91+ w 171K on it. NO mods all stock but I want some advice.
I plan on replacing the following; clutch, tob, pp, flywheel, rod bearings, intake man gasket set, waterpump, timing belt, full tune up, plugs, wires, all filters(fuel,air,cabin,oil), 02 sensors, flush radiator and cooling system, crank pos sensor, cam pos sensor, maf sensor, all new struts front/rear, flush tranny and put in drain plug, also been thinking about lower conrol arm bushings and A arm bushings. What else do you think I should do or do you think some of this is over ****. I just want to have a really good running SHO.
Any input is great!!!
pudge235
CT
sure bring it by lol it might be a long drive though. No honestly, do you guys think this is over ****. I got a hook up at a local parts store and I can all this stuff for next to nothing. I was also thinking about doing the valve lash adjustment but im not too confident on doing it myself. If I had someone who has done it befor help me then I would defffinetly do it!!
F-22 Raptor SHO
7015 feet above Sea Level
i have 143k on my 90...it will go to 250 if I have anything to say about it, so the miles arent a worry for me....but I have done all the stuff you mentioned plus other stuff. car is like new.
Redskull
Badass Mo'fo
New Haven, CT
I can give you a hand with the valve lash, but i don't have the tools anymore. Where in CT are you?
PS - it's a good bet that you won't even have to adjust it. It's usually safe to not even bother getting the shim kit/tools, etc, and just 'verifying' that all the clearences are in spec. Of course, if you do find one thats out, it just adds another week until your car's back on the road.
alan
Shoaz
Studly dood
Scottsdale, AZ
Personally, I'd say drive it a while and just put the money where it needs it. The basic maintenance stuff is always good, and if there are obviously worn or underperforming parts then replacing those is good, too. Just replacing stuff to replace it doesn't seem worthwhile to me, and there's always a little added risk that something doesn't go back together quite right and causes problems (like Beth's stray electrical connector last year).
pudge235
CT
i def want to do the 60K. So if you could help with the valves that would be awsome. Im in Stratford. Also I kind of agree with dont fix whats not broke theory but at the same time CT winters suck and I dont want anything to break on me during the winter so I figured I could get it all out of the way now rather then later.
Rockledge
Pluggin' away
Connecticut
TRSCobra said:
These cars have cabin air filters?
Not the Gen I or Gen II.
However, my '97 GL has a cabin filter, so I'd have to think that the Gen III SHO's also have them...
Minnesho
i was wrong
MinneSHOta
i would do all the suspension components for sure in addition to the 60k. my car is a 93 and 14 years have obviously taken a toll on the suspension. every part i replace makes my car feel like its got new live rejunienated into it!!
ohfosho
ontario SHOwner
ontario, canada
dont forget the valve cover gaskets, and new plug seals. also clean the throttle body and intake. new timing belt while you doing the water pump and cps, and cid. oh and lower rad hose.
qiksho
SHO Addict
Fargo, North Dakota
Add Front hub bearings to your list if they are still original. If you replace them before they catastrophically fail then you can re-use the hub. If you wait till they fail you need a hub and bearing.....
I found this out the hard way....twice... :bonk:
