Too cold for Bypass???
Puckpimp71
Miami, FL
It's down to 50 in Sunny Miami, so do you think I should undo my coolant bypass? My car's been running a bit under the L in NORMAL but still above the C at the bottom. I THINK it's okay, but what do you Northerners do when the temp drops to the high 40's-low 50's???
yamahaSHO
E85 whore
Arkansas
In Miami... I would not worry about it!! Here in dry Denver, AutoSHO has not had any problems and its been in the teens here in the last few weeks.
Machspeed
Former 1991+ owner
Santa Barbara, CA
Ya really 35 degrees here so far no problem. You really dont need to worry about it, if you had a problem, just think about all the guys who live in snowy areas.
masho95
got Zex?
Chicopee, MA
Puckpimp71:
If your car is running under the L in normal for temperature I'd check for a stuck open thermostat. There's no way it should be running that low in 40-50 degree weather.
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Puckpimp71:
Here's a big F U !!!
40-50 is shorts and a T-shirt weather... practically tropical. The last few times I've driven my car its been in the teens.
The only difference I notice is in sub-30 degree temps the gas pedal is a little stiffer, almost certainly from the TB shrinking from the cold. Never had it freeze though, or had any trouble with it returning to closed. I have considered running it again for the winter, but since the reason I bypassed it was because one of the hoses split and left me stranded, I'm hesitant to run the loop again. New hose would keep it reliable I'm sure.
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
mine stays just below the L on the dash gauge. And I know the engine is up to temp (185-190) with my mechanical temp gauge. wink
Use the dash gauge for reference... but dont think it is accurate. Buy a real gauge if you want accuracy :p
Dr. Tweak
Mad Scientist
Northern Vermont
Is there anyone who has had a problem with the TB cooland bypass? Because it get really cold up here but I like the idea of not having to worry about them when taking my intake manifold off... shrug
Puckpimp71
Miami, FL
If your car is running under the L in normal for temperature I'd check for a stuck open thermostat. There's no way it should be running that low in 40-50 degree weather. </strong>[/QUOTE]
I thought about that and I'm going to do it tomorrow, but my car's temp only seems to really drop when I get on the highway. I know the orginal reason for coolant in the TB is to keep it from icing over in Alaska or where ever, I just wanted to double check on what you guys did during the winter. I'd gladly trade my sauna for your snow! I haven't played pond hockey in forever.
projectSHO89
SHOless In St L
Seems many misunderstand the purpose of the cooling loop in the throttle body.
It is there to prevent icing in the throttle body when operating under primarily humid conditions. Ambient temperature is of lesser concern than is the humidity. As air rushes through the throttle body, it is cooled by the Venturi effect. This cooling wrings the moisture out of the air and simultaneously cools the air. When conditions of both temperature and humidity are just right, the moisture can condense and freeze, causing ice to form in the throttle body.
The coolant loop runs hot (190-220F) coolant through the throttle body to keep it warm enough that ice formation should not be a problem in any operating environment.
If you want more information, talk to a piston engine aircraft mechanic about icing in carburators and fuel injection systems on their aircraft. Those guys have to do anything possible to prevent it.
Steve
Yes not much recourse left at 5k feet...
I had my side draft carburetor slides freeze one day on a TR7. If it does freeze what happens is the throttle will either stick or slowly close and stay there. At any rate just shut the car off and sit for a couple of minutes, the heat soak is then your friend.
krupt89
Barrington RI
Ive never heard of this bypass before, what is the advantages and disadfantages of it and how is it done :confused:
Edit: Just thougt about it for a minute and im guessing it keeps hot coolant from entering the TB, thus keeping it cooler shrug
<small>[ December 19, 2003, 08:30 PM: Message edited by: krupt89 ]</small>
Puckpimp71
Miami, FL
krupt89:
You're right about what this mod accomplishes. Sorry to reply with this, but do a search and look for replies by SDPatt. He posted a great picture of how it's done and it's more complete than anything I can tell on my own. Best part is that it's free.
