Tire size help needed.
jokerinthemist
Central Maine
Searched the forums but couldn't find an answer. Can I use 245/50/20 tires in place of my 245/45/20 tires without any rubbing? The diameter difference is 1 inch & the sidewall is half an inch taller. Thanks
Should be no problem with stock offset wheels as far as rubbing & other concerns. However, the more important thing is the % difference in overall height, not the absolute difference. You can use this calculator to see the %ages:
https://www.tacomaworld.com/tirecalc
and your specific question
https://www.tacomaworld.com/tirecalc?tires=245-45r20-245-50r20
If you change all 4 tires, the AWD system will probably be just fine with it. BUT your odometer and speedometer WILL be off a significant amount, over 3% in this case. You CAN have the dealer update the PCM to accommodate, so that is the good news. Or if your SHO is tuned, your tuner can do it for you.
People generally find the 255-45-20 tires to be cheaper and some, also better handling.
https://www.tacomaworld.com/tirecalc?tires=245-45r20-255-45r20
Sholab1
United States
No problem lol, I had that this morning myself. I turned bbq grill on went inside house and fell asleep on couch with coffee in hand till wife asked what the **** I was doing, lol
Sent from my XT1254 using Tapatalk
bmytych
