Timing questions(Crank, Cams, etc...) HELP ME!
JoeHoe_SHO
SHOPUKE
Rochester NY
I'm about to sell this **** as is I'm tellin' ya!
Okay, I took care of the timing belt tensioner problem...tightened it by hand. Then, I'm putting the timing belt on, and the rear cam moved on me. Can I just crank the crank around a few times to fix this, or do I need to take the belt of again and reset the cams.
Spell it out for me please!
To install the timing belt on the cam and crank pulleys they MUST be oriented as shown here. If one camshaft turned from the index mark at 12:00, use a strap wrench to line it back up. I have emailed you the timing belt installation procedure (I thought I had already done this for you). To set the tension, follow the procedure.
JoeHoe_SHO
SHOPUKE
Rochester NY
Scott
Thanks a lot, I really appreciate it. thumb
Sorry, I deleted the procedure you had previously e-mailed me before(was a few months ago) due to the fact that my hotmail account was getting a little too big.
