Hi !
I just want to be sure that i understanded everything ... In instructions
If a new belt is being installed, perform the following steps:
Position the timing belt tensioner tool T93P-6254-A or equivalent, using the power steering pump bracket holes.
Hand tighten the timing belt idler bolt.
Using a inch lbs. torque wrench with belt tensioner attachment T93P-6254-A, rotate clockwise to 4.3 inch lbs. (0.5 Nm).
Tighten the timing belt tensioner bolts to 27-37 ft. lbs. (36-50 Nm), then remove the timing belt tensioning tool.
And when i done that,, doesnt i have to thouch anymore that timing belt idler bolt?? Is it just ok if i left it just hand tighten position ??
Thanks
Thanks
