And i just put these heads on, and started it for the first time today. Was a perfect and healthy car before i swapped the heads.
My apologizes for the frantic post. Was sorta nervous and doing about 10 things at once.
The thing is running like timing is off or plug wires are wrong, but as i said i check the routing several different places including here and they are correct. So that leaves Timing correct? The belt is probably off a tooth and is throwing a wrench in the thing and making it a nightmare. Did a cylinder balance test and 4 and 6 come up a sever problem so we pulled the plug and 6 looks rich while 4 &5 seamed lean. Did a compression test and they all tested out at 150psi. Which i thought was avg for our car at 160,000 miles.
The motor before i swapped the heads ran fine no issues no odd noises. So im certain its not toast or anything, Had rod bearings put in it 2 years ago and the car has had a lot down time and see about 10k miles since. And i had the oil pan off as well (had a crack and leaked so i picked up a fresh one) and there was No metal shaving and all the bearings look good and healthy.
