tery
Silvia survived the purge- summer car
Hey folks, the snow is almost gone here so I'm about to get back to it with the Shos. Someone had posted an idea about the random clack/tick noise I'm getting at idle on my manual tranny 95..They said something about if the noise goes away when you put in the clutch, it means that??? and that's where I lose the memory and I can't find that thread response. What does it generally mean if that random clack/slap/rattling noise stops when the clutch is help in, you can hear the noise pretty good on the vid I uploaded. Here is is again,
It goes away when the idle is up and/or goes away when the clutch is in..
Also, if you just let out the clutch slowly without a lot of rpm, it pops of out 1st gear with a nasty feel. If you give it 2grand rpm or more, it works fine, and if you drop the clutch like popping it at a light, it stays in gear...???
Does this seem like a throughout bearing problem. I thought someone had said that if there was a ceramic one in there, that they were rattly and loud sometimes
