they broke... again
inverse1216
daytona beach, fl
k well i snapped my rear endlink going into a turn, now being the second time first time was in a taurus lx. so ive been doing some research cause i would like to put in a heavy duty endlink or something other then stock. here is what ive come up with.
tpr rear endlink kit from sho nut?
rear swaybar links from sho shop?
rear endlink kit tpr from midwest?
moog unit from rock auto? (im aware that the autodrive brand is the same thing)
trw federal mogul from advance auto?
out of these does anyone know which is the best choice? keep in mind im looking for better then stock and something that will handle good force. thanks
n8rsk8r
Hey Where's my post?
Olathe, Kansas
any are going to be what you are looking for, go with the place that is going to get it to you fastest, and if you have a problem, then you can return it easy, autozone, oreillys and the like sell the heavyduty thermoplastic tpr, so go there, autozone is where I went.
nathan
inverse1216
daytona beach, fl
that was faster then i thought thanks ill swing by a autozone by me how much did u end up paying for them cause i have a wide range of prices between those that i posted.
n8rsk8r
Olathe, Kansas
I think like 18.00 bucks a piece, ask the dude to make sure your getting the tpr
no prob dude, I have broke two, same car, one tpr, so it is cool.
nathan
inverse1216
daytona beach, fl
yeah the stock ones are weak as **** both of them snapped clear off guess i have to slow down on the turns :D. thats not to bad for each for those who are wondering what the prices are for the links they are as follows same order
43.69
24.00
40.00
dont know on the moog ones
41.39
btw, n8rsk8r did u do the front endlinks on ur car also? cause i figured i might as well do those to. what did u use?
Yamaha V6
SHO Enthusiast
Rhode Island
IIRC, TRW sells a larger diameter than normal rear endlink kit, with sleeves. Napa carries those from memory.
n8rsk8r
Olathe, Kansas
yeah, I did everything up front except bigger sway bar and those bushings I have NOT done, they are going to be soon, but the heavyduty endlinks, I hear those don't last that long, we will see.
The ones you are getting are the right length? The last one you put on should be very difficult to get the nut started.
slickn56
North Attleboro, MA
I have the midwest sho rear endlink kit on my car..... havent had any issues at all with them. The stock plastic front ones on the other hand, I keep on wearing them out.
N3FOL
Pennsylvania
Go for the TRW rear endlinks from Advance auto. They have blue polyurethane bushings on them and are definitely heavy duty. I personally liked the endlinks on my 95 SHO. $ 9.00 each @ advance. Good luck.
inverse1216
daytona beach, fl
yeah i believe they have some one ebay that i was looking at. is advance a affiliate of another store? cause i dont think i have an advance auto in illinios.
N3FOL
Pennsylvania
If you go online under the Advance auto name, the website will automatically show partsamerica.com which is also advance auto to say the least. From what I heard, the TRW plant burned down a few months ago according to a sales associate from Advance. As a result, a number of TRW chassis parts are running low on supply. So if you can get a chance, grab what is left out there soon.
Dave Kegel
Chicago suburbs
Advance also sells the MOOG endlinks, which may be what you're thinking of. They use blue TPR bushings and heavy duty endlinks. NAPA also sells them.
Dave Kegel
You can get the TPR Moogs from O'Reilly's. Ask if they have their house brand (Autodrive, I think). Same part in a different box for a few bucks less.
If you buy from AutoZone, be certain you check on the warranty first. They have gotten very stingy on warranty term lengths the last several years.
Advance Auto Parts is part of Parts America. Go to www.partsamerica.com to locate the nearest store to you and to determine which of the chain stores is in your area.
