The easiest way is to use all 3.0 L accessories. Timing belt setup, water pump, accessory drives, engine mounts, etc...
Alright Gents, it's time I started putting this bish together. I ordered the rotunda kit and I'm going to start with the lower gasket set first before I save up for the upper gasket set. Should I order OEM or felpro? The only difference I see is cost. Will one brand give me superior performance and reliability? Also I'm looking on RCM, is there a cheaper place? Thanks guys!
. . . Question: When I put air in the chamber I hear air leaking past on the bottom end. My piston rings are seized (caked with crud really bad) and don't expand out at all, they are just stuck inside of the ring lands and they wont move, Is it time for new piston rings? Also can I use a 3.0 water pump nose with a 3.2 housing? I plan to run a 3.0 timing setup and acc.
