the story in pictures
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Wow, keep that pressure plate, its a Clutchmasters Stage 3 (Sho Shop Race) clutch - Double diaphragm pressure plate.
If the clutch isn't slipping, I would replace the TOB and Fork and put it back together.
bolsterboy
South Side Chicago
ok, so tell me, my clutch was slipping on my way home from getting it from the guy i got it from, is that the tob, cause that died on my way home, or at some point could put in the old clutch, cause that job sucks
SonicRiot
Handbanana!
CT
Wait.. you replaced your clutch without replacing the TOB? Did you resurface the flywheel?
(P.S. some of the pics don't work for me b/c I get 3 million popups and it crashes. My computer, not you)
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
You should always resurface the flywheel when doing a clutch job, no matter what.
I want your old, used pressure plate. PM me if you want to get rid of it.
SonicRiot
Handbanana!
CT
Not re-machining the flywheel after a clutch job is like sticking on a set of brake pads without remachining the rotors!!!
tinkerkathleen
